Unanswered question
Sorry I accidentally set my question as resolved so post again.
I switched the "block international call" off but still cannot make an international call or SMS.
It has been more than 12 hours.
I do not have add-on. Someone said I cannot make international calls without add-on.
I checked the pay as you go.
View Pay As You Go rates
UNITED KINGDOM
Zone 1
See Pay As You Go rates for all countries in Zone 1
0,30 CAD / minute
Note: You can also add money to your wallet to Pay As You Go for additional international calls not in your plan.
I found the solution. I added some value in my wallet and problem solved.
Add on is much cheaper 6$ for 60 minutes : 0.10 cdn / minute
Yes addon is cheaper than pay as you go.
You should consider getting an add-on if you plan to call the UK on a regular basis.
Does the addon require money in the wallet or will it take it from your CC?
Ken answered
E answered
Anne answered
MT answered
Huaqiang Kang answered
Huaqiang Kang posted a new question
