iPad Pro 2018 is compatible on Fizz LTE?
Yannick C. #1437
Posts: 1 ✭✭
in My Mobile
If a get a SIM card for data only does it work on my iPad Pro?
11
Here is a thread that might help you :
https://community.fizz.ca/questions/1814610-data-ipad-pro-12-9-2018-third-gen6 -
Yes it works for me. iPad 6th generation. First it doesn't work, I upgraded to latest 12.1 firmware and it works beautifully after. Just did a reboot after firmware upgrade. No configuration needed.3
