Why wont my LG V20 wont connect to LTE?
I set my phone to auto switch to LTE. I entered all the APN info. I restarted my phone. Still no LTE connection yet my friends phone will connect to it. Is there a unique setting needed to an LG V20? Thanks!
Ryan
Ryan
Ryan
Level
1
117 / 750
It looks like all versions of that phone have the frequency support for LTE data, but not all support voice calling/texting when connected to LTE, maybe that's the problem you're experiencing? Do you know which version you have (Global, AT&T, Sprint, etc.)?
Did you find this useful ?
No (0)
Yes (0)
MoYe
MoYe
MoYe
Level
3
3973 / 5000
Is it just the LTE that doesn’t work , does 3G work ?
MT
MT
MT
Level
5000 / 5000
Did you verify phone compatibility with Fizz
Ravnoor
Ravnoor
Ravnoor
Level
1
267 / 750
What model number (H918, VS995, etc) is it?
Mohammad
Mohammad
Mohammad
Level
3
2349 / 5000
Varies from location to location. I get 4g in my house but not my basement as well some parts in carleton university and not others.
E
E
E
Level
3
3348 / 5000
Some phones like the iphone5 are not compatible - check your phone compatibility. If that isn't the issue, consider messaging Fizz on the chat bubble or via FB messenger.
