Unanswered question
No data plan, but applied data perk. How do I check usage?
I have no data on a plan, just text messaging.  I applied the 500 mb of data perk and it shows in the 'In Use' section of 'My Perks'.  The data works, but how do I check my usage?  The "See Usage" button is greyed out.
Fasieh
Fasieh
Fasieh
Level
Hey! Depending on the phone that you use there is a data usage calculator in your device where you can track your data's if the one on the website doesnt work.
@mh, yes. I don't have data plan . I can apply data upgrade reward. I can also gift my data perk to my friend as well because i don't need it. I can't gift out my unused data upgrade though.
E
E
E
Level
3
3348 / 5000
Try to message them on Facebook. It's a known bug but it's random.
MoYe
MoYe
MoYe
Level
3
3973 / 5000
Contact Fizz on Facebook messenger with this link :
https://m.me/fizzca
Pat
Pat
Pat
Level
2
874 / 2000
I don’t have a data plan and have data upgrades. I can’t see the usage either. I believe those with data and upgrades have the upgrade data added on to their meter. And it lasts for 90 days.
Mohammad
Mohammad
Mohammad
Level
3
2349 / 5000
Display bug. Just use an app or bulit in app of your phone if there is one. Its nit very accurate but its acceptable.
MP
MP
MP
Level
2
1739 / 2000
Thanks @Pat D., so each of the data Upgrade when applied, last 90 days?!
My "welcome" perk from Fizz has a 90days countdown from the 1st day I joined Fizz. Whenever I apply that, how many days can I expect? Thanks in advance!
Pat
Pat
Pat
Level
2
874 / 2000
Once applied, you have 30 days to use perks.
