Are non-LTE phones supported ?
Emmanuel T. #1147
Posts: 4 ✭✭
in My Mobile
Hi there !
I'm using "dumb" phones so that I can enjoy offline life more.
Before I move to Fizz (for voice and SMS only), I was wondering if one of those two phones are supported ?
- Nokia 3310 3G
- Nokia 8110 4G
In case you don't know those models, maybe a more general question: can I make calls with Fizz and a phone that doesn't have LTE/4G ?
Thank you !
- Nokia 3310 3G
- Nokia 8110 4G
Thank you !
19
Yes. In fact, many of us are on 3G for data these days as well. You need to make sure your phone is able to use the bands that fizz uses for 3G. (If it's compatible with videotron, it will work with Fizz).
For a phone that only allows 3G or HSPA preferred:
Calls and / or mobile data: The phone must support the 1700/2100 MHz frequency (also called AWS)14
