My son have a cell plan with Videotron for 25$ per month tax included for zero data, only unlimited texting and 200 mins of voice. He asked me to have data so I have a question about that :
Is it possible to add voice by the minute by putting money in the wallet so my son can call if needed (he may use less than 15-20 mins per month) to the data only plan ?
Yes it's possible.
You can have a plan with data only
You should simulate a "create plan" to see possibilities.
Thanks and I know it's possible (I have a data-only plan because i'm deaf) but what about the cost by minute ?
I think it's 25 cents / minute for local calls - see attached. So I suppose if your son calls Montreal to Montreal for 20 minutes that would cost $5. Keep in mind that it costs $6 / month for unlimited voice calls according to the Fizz plan customization.
I can see the pricing when I create the plan but that's not the question. I need to know if it is possible to charge the wallet and use it when my son need to call ? And how much it cost by minute ? This is what I need to check before commiting to a plan.
