Somehow all my calls are being dropped after 2:56min, really frustrated..
Doesnt look like this will be fixed anytime soon..
It’s an improvement, earlier today calls dropped after 100 seconds.
I've seen this reported several times already. It happens when roaming in Canada and the US. I personally don't even see Fizz Ext as an option so I can't check it out myself, but if you do a search you can find several threads on the issue. I don't recall seeing a good solution to the problem, unfortunately.
My wife had the same issue yesterday.I made a test call this morning for 3 mins & no issue .
Bravo! This has been fixed now! Thanks Fizz!
Thank you for your patience M G!!
Jay
