Hi MohammadAmin
Yelena is correct. That version of Xiaomo phone seems to be built for use in China and it does not have dual-frequency support for 1700/2100 MHz (also called...
Hello Éloïse,
Apologies for the unpleasant situation.
Have you verified if your phone's APN ( Android) is configured as shown on the FAQ Lieux has provided? If your phone...
I have a FIzz canadian account with US coverage. While in US, my phone is dead, if i buy a new unlocked iphone in Florida, will it work automatically when i put my FIZZ SIM CARD...
Hi Francois
Please check the exact model number is starting with A...., I checked couple of model and they are compatible, but please check the right model
https...
Hi Xine,
Try one by one those 3 solutions who solve a lot of problem
* Restart your phone
* Try enabling air plane mode for 30 seconds then disable
* Take out your SIM...
I've been in Toronto for just over a month and today my data stopped working for no reason. Calls and text still work fine.
My phone tells me I'm connected but Fizz EXT...
Hello Robert,
Please perform a new reboot of your phone and after enable airplane mode for 30 seconds then turn it off and test...
