Only way to get any signal is by using "Fizz EXT", long term solution ?
Gabriel F. 907
Gabriel F. 907 Posts: 23 ✭✭
Hi, yesterday I made a post and some users helped me out a ton. However, I was told something about my "solution" that might not make it a long lasting one.
Basically, the only way for me to get any signal at all with Vidéotron/Fizz, is to use Fizz EXT. My phone is fully unlocked but seems to work on ANY carrier OTHER THAN Vidéotron/Fizz for some reason, I am assuming the bands that it uses.
The only way to have anything at all is use Fizz EXT. I was told that Fizz would likely not allow this for very long. I'm currently waiting in the chat but in the meanwhile what are your thoughts ?
