Will I be able to join the beta program even though I did not receive my SIM card?
Alex K. 623
Posts: 1 ✭✭
So it says you can only be part of the beta program if you activate the SIM by November 20th, but I still have not received it in the mail even though I ordered it a long time ago. Does this meant that I will not be able to participate in the program? I really can't afford to get charged full price.
8
You are out of luck Alex.
You had to activate the sim by last night.
However the launch prices are very attractive compared to the competition.7
