Why doesn't my data work on fizz ext network?
Max R.
Max R. Posts: 1 ✭✭
When I am on the fizz ext network my data won't work at all. Calling and texting are okay but none of the recommendations I found on here seems to fix it.
There is a capital R letter on the network triangle thing too instead of the usual 4g or LTE
  • DinoS
    DinoS Posts: 626 ✭✭
    You're Roaming, make sure you turn roaming on, also you need have Canadawide coverage too.
