My SMS doesn't work! Can't receive any calls or text.
Simply put, I cannot receive any calls or text (SMS) with this service. Also the support chat bubble is gone. If I can't fix this I have to give up the service.
Nathaniel
Nathaniel
Nathaniel
Level
Hi Nathaniel,
This is a known issue....can you power-cycle your device and let me know if you have the same issue?
Thanks,
Community Team
Did you find this useful ?
No (0)
Yes (0)
Curtis
Curtis
Curtis
Level
I am having the same issue. I tried power on off already on iPhone 6
Johanne
Johanne
Johanne
Level
Meme probleme
Valérie
Valérie
Valérie
Level
1
153 / 750
On your Fizz account, go to My Plans, then click on Manage my Plan, then try to click Unsubscribe. After doing all that, the Customer Support Chat Bubble will appear. And then, you can finally point out your problem with SMS. I just chatted with them 10 minutes ago for the same problem as you, but so far, they could not find a solution. They say the Technical Team is working thins out asap...
Nathaniel
Nathaniel
Nathaniel
Level
Tried Power cycle, remove sim, wipe phone and reset, reset network settings, sign out and back into ICloud... Nothing works.
I can't even get in touch with a Fizz rep with the live chat since it is down via browser. Messaged Via facebook and got one response in 6 hours wait time, no solution.
Nathaniel
Nathaniel
Nathaniel
Level
Tried, there is no 'Unsubscribe' option.
Same issue for me. Everything worked until yesterday. Stopped being able to receive texts yesterday and could not even receive calls today as well. I am still able to call out and send texts though. Chat does not work...
Nathaniel
Nathaniel
Nathaniel
Level
Hi Georgina!
Update for everyone else, still waiting for a solution with the specialized number port team to see how to fix a number port issue.
I had this issue twice with Fizz. The first time it took a week for them to fix it. The second time it took 11 days... Don't hold your breath.
Johanne
Johanne
Johanne
Level
Cetait quoi le probleme les 2 fois?
Nathaniel
Nathaniel
Nathaniel
Level
UPDATE: STILL nothing! Can't even transfer my number out since Fizz has not properly set it up! In a 'hostage' situation of sorts now with their chat service/technical team.
Nathaniel
Nathaniel
Nathaniel
Level
@Alexandra Y I K E S
I should have put more time into this decision had I have known it was possible.
Try this...it might help.
Go to Settings > Network & internet > Mobile networks > Network operators > Search networks
Choose Fizz EXT
I chose the first one Fizz EXT RAT:LTE
Wait a couple of minutes
Go to Settings > Network & internet > Mobile networks > Network operators > Select automatically
This unlocked all the old texts for me and allowed receiving of texts and calls again.
However, I am getting the same issue again but I think it's because I have a low signal. It may work for you if you have an adequate signal. Good luck.
Koodos to Fizz.    See what I did there?  :)
I tried to to submit another form, but it seems that's down now as well. <sigh>
Bonjour Johanne,
Voici une fiche qui peut vous aider : https://fizz.ca/fr/faq/je-ne-recois-pas-dappels-sur-mon-t...
Si toutefois vous avez la même situation, n'hésitez pas à contacter nos agents par clavardage ou Facebook Messenger.
Corina
Fadi
Fadi
Fadi
Level
I have the same issue. Im not receiving calls and can't make any. Also, can't send or receive text messages. However I added 60 minutes for 3$ as an add on and I can make calls but my texts don't work. I reported the problem 4 days ago and it was escalated 2 days ago but still have not gotten any updates for a fix. As soon as my minutes end, I have to top it up for my phone to keep working.
