Works great in Ottawa but I was hoping to use when I travel. I was unable to connect in Ontario once I was outside of the NCR. Is there something I have to set on my phone?
What coverage did you take with your plan? If you choose Canada wide you shouldn't have any issues, maybe try manually searching for an operator in your settings? You have roaming enabled, you probably do need it enabled, but you never know.
