Problem when i send a MMS
Hey everyone,
I am trying to send a picture message and for some reason i can't.
Image result for disappointed gif
Is anyone else having this issue also? If yes, did you find a solution?
xavier
xavier
xavier
Level
1
336 / 750
Did you find this useful ?
No (0)
Yes (0)
Queen
Queen
Queen
Level
1
549 / 750
I had the same problem and after reading the Help, I couldn't find any answer the really applied to our case.
So I contacted the customer care service via chat. They troubleshoot a bit with me, but it still didn't work. They had to escalate to the technical service unfortunately. But luckily, it was solved within 3 days! :)
Best of luck,
Queen
FizzWiggler
FizzWiggler
FizzWiggler
Level
2
1458 / 2000
Hi Xavier M
Did you get your MMS sorted yet?
I believe I am having a similar problem.
Cheers
