Just activated my line with Fizz,
It seems that my data is not working with my android device, and advise on what I can do?
Thanks!
Hi there,
First thing to make sure is the APN settings (see APN topic under Help) and if that is all set;
This may be due to the version of android that you are using, try to update your OS or power-cycle your device.
Cheers!
Hi @Eon,
Issue was with my APN settings - thanks!!
