Wrong phone number dhiwed for outgoing MMS ?
mwong
mwong Posts: 88 ✭✭
I had a 343-xxxxxxx number last year, and I cancelled this sim card in summer. I reactivated it in October to keep the stabilization price with different 613-xxxxxxx number. Call/text/data all works as expected, except my phone still recognize this sim as old 343 number. Yesterday I sent a few MMS with photo to different people who use non-fizz cell. Both told me the MMS messages care from either 438 or 418 area code, not my 613. Anybody faced this before?only MMS, regular text without picture works fine
  • SittingRam
    SittingRam Posts: 320 ✭✭
    This happens on Iphones sometimes if you do a network reset. It usually fixes the problem
  • SittingRam
    Okay, i just read your second message. Sorry
  • mwong
    mwong Posts: 88 ✭✭
    I'm positive it's related to the old sim card when it's only $2/month for Fizz 4g data. My friend who bought new sim card this year can reuse this sim just fine with correct new number in setting. Mine always showed my old 343-xxxxxxx ( recycled) in phone settings. As long call in/out with new number ok, I will just leave it as is.
  • Kovid
    Kovid Posts: 588 ✭✭
    That's weird but I have never experienced this.
    Fizzy Posts: 10,903 ✭✭
    What phone are you using?
    Here are 2 things you can try:
    1. Try your SIM on another phone.
    2. Backup your phone. Do a factory reset. Restart your phone.
