Cost of Data when one exceeds their mobile data allotment with Fizz Mobile 20GB Data plan?
Hi I’m just wondering how much is the cost per extra Gigabyte if I exceed my 20GB Data plan allotment in my Fizz Mobile Plan please?
  • Serge O. #3665
    Serge O. #3665 Posts: 535 ✭✭
    If look at your plan and choose addons it should cost $12.00 for 1 gig and $20.00 for 2 gigs
  • Serge O. #3665
    By the way you can t exceed your data plan because it is prepaid. You will have to choose addons at the end of your data plan. If not it will stop to work.
  • James L. #3513
    James L. #3513 Posts: 12 ✭✭
    Wow 20GB is a lot, but you can always go to add-ons and pay for the extra data you need!
