I have read and tried all the solutions, but still cannot receive any SMS?
Gina O. #2941
Posts: 1 ✭✭
in My Mobile
After going through all the questions and suggested solutions, nothing seems to fix it. The SMSC is correct. I have tried with different phones (iPhone, android). In no way can I receive any SMS. It does send them (with a delay).
So far, my experience with Fizz has been absolutely horrible. Thus far, I would not recommend it to anyone. Between troubles with login, SMS, 2FA... this has taken up too much of my time to be worth saving a few dollars a month.
5
If you just ported recently (less than 48 hours) from another provider then maybe the porting process has been completed 100%.
Otherwise you need to contact Fizz3 -
Your phone number may not be ported successfully.2
Do you have the SMS plan at least?
Also SMS 2FA people need to stop using that it's not secure at all!
Use 2FA applications like google authenticator instead2
