Do I need to set up APN?
Hermine Y.
Hermine Y. Posts: 20 ✭✭
I was wondering if it's necessary to set up APN. I do NOT have a data plan, but I'm able to use the upgrade data without setting fizz APN. Fizz said you need to have a data plan to be able to connect to their mobile internet network. If I set up fizz APN, will I loose their internet network? I'm confused
Best Answer
  • Kenny L. #23
    Kenny L. #23 Posts: 794 ✭✭
    Interesting you can use upgrade data without a data plan. I thought that was not allowed...
  • Sometimes you need to setup the the MCC and MNC as well as:
    Fizz APN settings are:
    APN: mobile.bm
    MMSC: http://mms.mobile.bm
    MMS proxy: mmsproxy.mobile.bm
    MMS port: 80
    APN type: default,mms,supl
    .The MCC should be 302 and the MNC should be 500.
